T-vis gone bad, engine damaged
Postby Gert » Fri Jun 01, 2018 6:51 am
Hi, Little note from me, I am not often here, just drive the car.
Just for info: last week, butterfly from cilinder 3 came loose. So the screws and valve went walking through the runners and every piston is having a little damage.
It appears that the T-vis rod from 3+4 came loose, causing the valves to judder or I don't know how you call it.
The screws from cilinder 4 were already loose too.
Anyway, the engine is open again. In 2000 I rebuilded the engine and since then I drove about 85.000 kms.
Gert
Re: T-vis gone bad, engine damaged
Postby FC Zach » Fri Jun 01, 2018 7:04 am
Ouch! ! Only that many miles?! Wasn't even broken in yet!
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby Gert » Fri Jun 01, 2018 7:19 am
Hmm, the T-vis itselfe is from 1990 and lasted 273.826 kms.
Gert
Postby FC Zach » Fri Jun 01, 2018 8:09 am
That's assuming it hasn't been messed with. . . Aren't the screw ends deformed? I believe so, that shouldn't have happened.
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby underscore » Fri Jun 08, 2018 8:05 pm
They're supposed to be, we were going to weld/braze the ones on my engine when rebuilding it to ensure they couldn't come out and found they are deformed so it should be impossible for them to come out unless someone took them out.
Postby Gert » Mon Jun 18, 2018 1:13 pm
Yeah, should be. Anyway, they came out. Two are rock solid, but the other two are (coming) loose.
But, as suspected, the turbo is damaged too. Any good ideas on that one? ATS turbo perhaps.
I live in Europe, so not much possibilities here.
Gert
Postby underscore » Mon Jun 18, 2018 9:14 pm
Can you get closeups of the ends of the loose ones? And what year is the motor? I wonder if Toyota only starting deforming the ends partway through production.
Postby Gert » Wed Jul 04, 2018 2:02 pm
Okay, sorry, took some time, but I have some pics.
The butterfly screws are deformed, but in the end, if the rod is coming loose, they are going.
Here a pic from a good one:
And these from cilinder 4. You can see that the screws are coming loose and the butterfly is already on his way to destruction...
The car is made in Japan in 1990.
Gert
Postby Gert » Wed Jul 04, 2018 2:28 pm
And a little movie from the T-vis:
https://youtu.be/UvjDRutDr78
Gert
Postby underscore » Thu Jul 05, 2018 1:54 am
Interesting, I seem to recall mine being deformed differently.
Postby Gert » Thu Jul 05, 2018 5:11 am
underscore wrote:Interesting, I seem to recall mine being deformed differently.
Just bougth a spare one yesterday = exactly the same.!
Gert
Postby underscore » Thu Jul 05, 2018 11:29 pm
I'll dig out my spare one and take a look, I didn't think to take a picture of the one in the car when the engine was apart unfortunately.
Postby Gert » Wed Jul 18, 2018 5:34 am
Parts are coming together:
T-vis:
Valves, bearings, etc:
CT27 is on the way. :D
Gert
Postby 88gt4DE » Fri Aug 03, 2018 6:08 pm
Same thing happened to me after my rebuild .... dump those damn things :x
2000 Toyota Tundra SR5 - 165K - Thanks 97JZA80
2008 Toyota Avalon - 110K - DD - Work Runner
2007 Toyota Rav4 - 145K - Wifey DD
Postby Gert » Tue Aug 28, 2018 11:45 am
Head is back.
Cleaned, flowed and optimized. This together with 264's and the CT27 should work well, I hope.
Gert
Return to GT Four Chat
