Choir Infantry
New member
As I was looking over the engine bay just double check wires and leaks (as I had gotten the car fairly recently) I came across this plug behind the air box coming from the harness out of the firewall without a place and do not know what it is for nor where it should be plugged into. As it stands the car does run and idle perfectly fine but I would rather know what it is than live in blissful ignorance.
