A
Anonymous
Guest
The 3S GTE from ST 205 did have hydraulic tappets? If so, why did reqiure to adjust the valve clearance? :shrug:
Thank you
Thank you
Kyoto":2ay3fqbm said:Not a big correction but the 205 heads have far better flow properties than both 165 and 185. They also lost TVIS but this is generally common knowledge, search and ye shall find.
Gurr":mbhrtkqa said:Also, the tranny is even stronger than the 185's.
Gurr":1o5q7gxr said:Uh, just to inform you... you can't put a 205 head on a 185 engine. They are designed differently. People swap the 205 engine in the 185's because it has more power and less miles. Also, the tranny is even stronger than the 185's.
how many ppl hav broken either for taht matter? what part of the tranny?
Gurr":fp7j0xz3 said:Uh, just to inform you... you can't put a 205 head on a 185 engine. They are designed differently. People swap the 205 engine in the 185's because it has more power and less miles. Also, the tranny is even stronger than the 185's.
