celicaGTS_T
New member
Eyy, how much do the FNO1r-c's cost for our cars? I'm in the market for a set-up instead of the OEM rims.
syko says":2rqrvh86 said:SuperWhite92":2rqrvh86 said:alltrac7":2rqrvh86 said:does anyone actually sell hood spacers for an st185?
Home depot sells them in the form of bolts and washers.
lol, thats funny. but what really is the point of making the hood raised like that?
Denver_whiteST185":24cptztf said:shaun, did josh put your old alltrac badge on his car...
BTW, both of you guys make me want to get some tires for my wheels and put them on....
celicaGTS_T":vt946gjl said:Eyy, how much do the FNO1r-c's cost for our cars? I'm in the market for a set-up instead of the OEM rims.
wouldnt it help out would the heat soak problem of the stock ic?syko says":36z6uj8c said:SuperWhite92":36z6uj8c said:alltrac7":36z6uj8c said:does anyone actually sell hood spacers for an st185?
theUNYTEDone":dx8izhoq said:those 3 spoker volks are straight up beautiful! i wonder how they would look on our car...how much did you pick them up for? i want them! haha...
celicaGTS_T":28a8aocz said:Eyy, how much do the FNO1r-c's cost for our cars? I'm in the market for a set-up instead of the OEM rims.
alltrac7":2dw591jz said:wouldnt it help out would the heat soak problem of the stock ic?syko says":2dw591jz said:SuperWhite92":2dw591jz said:alltrac7":2dw591jz said:does anyone actually sell hood spacers for an st185?
It came from that very junk yard, but it's off a camry all trac. I liked it, so i took it. Its slightly different from the 185 badge, but not noticable enough to see in the pic. I decided to just put that on instead of rebadging with a stock st165 sticker( I bought my car debadged)SuperWhite92":1feerv1k said:Denver_whiteST185":1feerv1k said:shaun, did josh put your old alltrac badge on his car...
nah, that's off that alltrac that was at Colorado Salvage a few months ago.
My underhood temps dropped dramatically. and the coolant temp dropped 10 degrees C while movingsyko says":1feerv1k said:lol, thats funny. but what really is the point of making the hood raised like that?
at3619":3pirv0xx said:My underhood temps dropped dramatically. and the coolant temp dropped 10 degrees C while movingsyko says":3pirv0xx said:lol, thats funny. but what really is the point of making the hood raised like that?
If you do so you will need to figure out how to raise the ducting for your tm air-air intercooler as well so it continues to have a tight seal around the ic. As far as actually blocking the hood, all you have to do in put washers (more or less washers for desired height) in between your hood and the hood hinges with longer bolts and adjust the hood accordingly. Its really easy. Dont wast your money on an aftermarket kit to block your hood... It took me 20 min and a bunch of hardware i had lying around from my swapalltrac7":fe3i143v said:has anyone with an st185 ever tried to raise their hood? im very interested in doing it...
alltrac7":2cgk2gev said:this is getting off topic, but on my car the duct, seal thing that goes over the ic while the hood is closed, has some tears in it.... should i be worried?
