ST205 motor ST205 M/T ST185 brake Tanabe AE92/101/111 height adjustable suspension (modified)
H hideki New member Nov 14, 2004 #1 ST205 motor ST205 M/T ST185 brake Tanabe AE92/101/111 height adjustable suspension (modified)
Z Zeus New member Nov 14, 2004 #2 damn! where are all these crazy 165's comming from.. looks like it has a custom rad? amoungst other things
H hideki New member Nov 15, 2004 #3 All from JP The radiator is brass type , 3 line? layer? , also there is an aluminium type for ST165.
M MrWOT New member Nov 15, 2004 #4 You know, it's a sad thing when you realize you are having thought of moving to Japan, just so you can upgrade your car easier :roll:
H hideki New member Nov 15, 2004 #5 Well , not so much easy ... We also hard to find the parts for 165 ,and those parts would be very expensive
A AWDtoyota New member Nov 15, 2004 #6 What needed to be modified to fit the Corolla (AE92/101/111) suspension?
H hideki New member Nov 15, 2004 #7 May be I told you before , you need to make a new holes for 165 on the rear shock blacket :wink:
A AWDtoyota New member Nov 17, 2004 #8 hideki":1jj2o59q said: May be I told you before , you need to make a new holes for 165 on the rear shock blacket :wink: Click to expand... What part is that? Is it where the 3 holes at the top, that bolt in the strut tower?
