BOV..which ones better?
Postby shoteh » Tue Aug 10, 2004 10:28 pm
hey which Bov would you guys prefer...Which one is better? louder?..I want a loud one to kind of show off haha but i dont know which one would be better for the st185...o yea and I heard that you need a flange for it but how would you get it on j/w. thanks
shoteh
Postby Griffin » Tue Aug 10, 2004 10:35 pm
I'm a big fan of the HKS SSQV, and you can mount it with a Samco T hose. I'm pretty sure 935 sells both of them.
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby mototebok » Tue Aug 10, 2004 11:02 pm
Yeah, the MR2 guys like the HKS SSQV because it mimicks the mr2 oem bypass valve.
You will need a Samco T coupler and then some way to pipe it back into the intake before the turbo, and after the MAF sensor.
The Bosch Bypass valve is also good for the same purpose.
I would not recomend venting it to the atmosphere unless you are running a standalone and no longer using the MAF.
-Adam
'88 Alltrac .... Got a shiny new turbo
'94 RX7 .... Other money black hole
'00 ZX6R .... Lime Green Speed Machine
mototebok
Postby Zeus » Wed Aug 11, 2004 3:26 am
the hks one wont actually casue stalling but it will cause the overrich condition.. so its not needed to vent back into the intake but def. recomended... the rich situation after shifting is horrible!
Blake Brown
Zeus
Postby Griffin » Wed Aug 11, 2004 5:42 am
Zeus wrote:the hks one wont actually casue stalling but it will cause the overrich condition.. so its not needed to vent back into the intake but def. recomended... the rich situation after shifting is horrible!
Funny - never cause a problem on my car :wink:
BTW - the HKS sounds VERY cool if you take the silver case and that stupid noisemaker airfoil off it.
Dave Staba
Sealy, TX
Griffin
Postby alltrac.net » Wed Aug 11, 2004 7:18 am
SSQV being a faster acting valve does not have as many stalling / rich issues as the other valves.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net
Site Admin
Postby scandinavian link » Wed Aug 11, 2004 2:24 pm
wish i'd gone with an hks. everyone told me to, and i was retarded. i have an apexi twin chamber. besides being kinda boring, the metal peice that allows for changing the sound likes to slide around all the time causing it to pretty much close up the vent hole. you'd think a brand like apexi would have done a better job about something like that.
i've thought about switching. but this is the second flange to be welded onto my intercooler, and i dunno if removing it for a new flange for an hks would be such a good idea.
oh well.
bryan -central ohio
2000 zzt231
1988 st165 (sold)
1990 st185 (brother's)
scandinavian link
Postby alltrac.net » Wed Aug 11, 2004 6:07 pm
Bryan, just remove the red ring. They usually end up loose and useless anyway.
alltrac.net
Site Admin
Postby OlyST185 » Wed Aug 11, 2004 6:34 pm
i would say that the HKS SSQV, greddy type-S and Apexi twin chamber.
these are proven to have the best reactions.
Avoir the Blitz
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
Postby tarmac165 » Wed Aug 11, 2004 7:39 pm
Hey guys, anyone know how the OEM MR2T BPV works? What makes it so special? All the MR2 guys I've spoken with seem to think it is the best think since canned beer.
Some people claim that the MR2T BPV is springless and remains open during cruise to allow air to bypass the compressor and supposedly aid in increasing throttle response while off boost. I personally think this is bogus, but I could be wrong.. What do you guys think/know?
I noticed it has two hose connections on it, and they both hook up to the same line that leads to the manifold, except the middle connection one has some kind of inline valve hooked up to it before it reaches the 'T'. Acording to the EPC, Toyota calls this little peice a 'Vacuum Transmitting Valve'. Sounds to me like a one-way valve intented to only allow vacuum through.
Here's a pic: http://www.seattlefenix.net/mr2/pictures/tuneup/engine_before_tuneup.jpg
Alex Amaral - White ST165 #3690
http://www.cardomain.com/ride/660778
tarmac165
Postby alltrac.net » Wed Aug 11, 2004 8:39 pm
The 2nd port is a vent. When the valve rises up, the displaced air needs to go some where. It goes out from that hole and into the vacuum that is in the line attached to the top. This is why it is T-ed into the main line. This similar to the Greddy Type S valve. Really, that port could be open, but being a factory valve it probably had to be sealed to prevent dust from getting in etc.
There is a one way valve so that it only lets air out but not in. This same valve is on the Supra Twin Turbo 1JZ engine that I commonly deal with and instead of that VTV it has a mini filter.
The main attraction of these valves is that the boost goes to the back of the valve so that it can't be pushed up. They operate very fast, and work well.
The 2 main problems with them is that they open so easily that they can't be used as VTA. Also, the diamter of the valve is very small and not ideal for higher HP / higher boost setups.
alltrac.net
Site Admin
Postby alltracman78 » Thu Aug 12, 2004 10:24 pm
Hey Robert, I like your avatar :D
I personally like the Fensport bov that I got. It sounds really good. No horn to make it sound different. Kinda expensive, and a long wait though..
* I was going to attach a pic of it, but I can't seem to find how to add stuff. I guess I'll have to go look. :cry: *
Postby 92 All-Trac » Fri Aug 13, 2004 12:38 am
I'll speak for the HKS valve also. It's the best all around bov out there IMHO.
Josh
1992 ST185
92 All-Trac
Postby pepper » Fri Aug 13, 2004 4:02 am
tarmac165 wrote:Hey guys, anyone know how the OEM MR2T BPV works? What makes it so special? All the MR2 guys I've spoken with seem to think it is the best think since canned beer.
Yeah, what Robert said :D I bought one of these a little bit ago and a Samco T-Hose for it. Now I just need to figure out how to support it (it's a fairly heavy bugger and there's not enough "grabbing" room on the side from the turbo to trust with the weight) and how to plumb it back into the intake - probably going to do some sort of Y connection with the PCV intake from my catch can. I'll be doing a writeup of all of it when I get it done, hopefully in the next month!
-Mike
Mike
'88 ST165
Vancouver, WA USA ------------------------------ mine
pepper
Postby alltrac.net » Fri Aug 13, 2004 4:32 am
The avatar represents me working on the forum!!
The MR2 valve is great, but for me it's a bit too large and bulky to be installed properly, unless you stick it direct to IC like the ST205.
The next best/cheapest option is the BOSCH/Porsche bypass valve. I put one in and it's working nicely. It slips into the T pipe like it was made for it. If I had a stock type alltrac to put it in, I'd go for that for the clean install.
A 1G DSM bypass valve would also work with a T pipe if you could find a proper tube flange for it.
alltrac.net
Site Admin
