Belt part # without A/C?
Postby Trance4c » Sat Aug 14, 2004 2:29 pm
There was a thread on the old forum which had the part number to the belt when you do not retain your A/C compressor. Anyone have that part number?
Thanks.
Trance4c
Postby jkgts1 » Sun Aug 15, 2004 7:36 am
PN is 99365-21000-83
took three and a half weeks for it to come in though. It was back ordered.
jkgts1
1977 Celica GT
1985 AE86
1990 st184 (3sgte)
2006 XB
jkgts1
Postby pog0 » Tue Aug 17, 2004 3:05 am
Clay,
The 3SGE belt doesn't fit unless you got the non turbo tensioner. I think I have another 3SGE belt if you want to try it. Basically brand new, I tried to fit it and it didnt work, $12 shipped.
I say go to your local shop and get a belt, I believe mine is like 104mm, I will double check for you tomorrow.
Kevin Hall
92 Gray ST185 - Sold
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
Postby mototebok » Tue Aug 17, 2004 9:53 am
385 length, 5 rib.
-Adam
'88 Alltrac .... Got a shiny new turbo
'94 RX7 .... Other money black hole
'00 ZX6R .... Lime Green Speed Machine
mototebok
Postby alltrac.net » Tue Aug 17, 2004 5:06 pm
At kragen, they have a part # for no a/c. The Belt was $8.99. To install it you have to put the belt on the OUTSIDE of the tensioner. You should get a ribbed tensioner, but many have just kept the flat one and it worked out.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net
Site Admin
Postby mototebok » Tue Aug 17, 2004 5:12 pm
I'm using the a 385 length, with the tensioner the way it was meant to be. :D
-Adam
mototebok
