Stock Boost?
Postby Gary » Wed Aug 18, 2004 4:33 pm
If your vacuum reading is stable, I don't think you have any leak.
It sounds like your MBC or wastegate problem, not the vacuum leak.
93 ST185
Gary
Postby alltracman78 » Sat Aug 21, 2004 3:41 am
Did you have these problems before you got the mbc? Even if your wg actuator is shot, it won't see any boost 'till the mbc opens.....
Postby toayoztan » Sat Aug 21, 2004 1:16 pm
I haven't been keeping up with this thread much, but does your MBC have a bleeder valve? I've heard from somewhere that unless you're boosting a pretty good amount of boost, the bleeder valve will cause spiking.
To me, it looks like your MBC is messing everything up. Make your own WITHOUT a bleeder valve (basically, don't drill that stupid hole ;))
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby -==L=a=N=c=E==- » Sat Aug 21, 2004 2:17 pm
toayoztan wrote:I haven't been keeping up with this thread much, but does your MBC have a bleeder valve? I've heard from somewhere that unless you're boosting a pretty good amount of boost, the bleeder valve will cause spiking.
Bryan
Yup, i traced it back to my Boost controller. Im in the process of snatching up an electronic one.
Thanks for the advice guys...
BTW, my wastegate has been modified to take 7psi at stock boost. Which is fair enough, since it used to run in a JDM, and then came here with all the controller pulled. No sweat though.
-==L=a=N=c=E==-
Postby alltracman78 » Sat Aug 21, 2004 8:57 pm
7psi is stock boost.....
