1stGenAllTrac
New member
Hi,
So I'm gotta swap my tranny since there's a gaping hole in it. Gettin around to it in a month or so, and probably going to do some engine mods while its out.
anyways i was reading the other post about engine swaps and i was thinkin, what are my options ?
I have another alltrac tranny but I was going to rebuild it - new synchros. Does anyone know the gear ratios on the camry alltrac? and is it direct bolt on? how is the center diff on it, and does it accept the celica half shafts and drive shaft?
Is there any other options, like a dogbox or short ratio box? does a 185 or 205 have a better diff, different ratios, ?
Also my need for tranny replacement is I blew up the inner CV joint, and it got smacked into the tranny a few times while attached to the wheel I've seen chrome-moly inners and wondering if anyone is using em?
K so any info/suggestions/links are gonna help out. thanx
