FYI 185's with WTA wanting a bigger rad
Postby coyoteboy » Fri Apr 15, 2011 8:41 pm
Well I had a top core from a CS and I didn't want to pay a fortune for a front rad (was getting requests around £70-90 quid for a stock one) and wanted a larger one anyway. So I went on the hunt for one and eventually found that, as I'm willing to sacrifice the air con and saved all that weight and space up front, you can fit an Audi 100 main engine radiator in there absolutely perfectly without modification to either...
570x305x42mm twin-pass core. £26.50 new on ebay!
coyoteboy
Re: FYI 185's with WTA wanting a bigger rad
Postby Corey » Fri Apr 15, 2011 9:34 pm
Great info, thanks!
I'm planning on switching to wta soon and this will help.
Corey
Images: 50
Postby coyoteboy » Fri Apr 15, 2011 11:12 pm
No prob :) I'll add some more pics as I complete it. For now...
There's an 8mm and 16mm hose ports that need to be capped off, the 8mm one takes a bit of care as it's close up behind the slam panel and could easily be snapped off when pushing the rad in. And a temp sensor hole too, but mine came with a blanking plug in it. The two main hose connections are 32mm, same side, front facing.
Room in front to re-install the air con rad fan and another if you wish, I'll have that and a 10" SPAL pusher in there. There's also a slight gap of about 1.5 inches between it and the main engine rad behind, in case you wish to trap something in there or route cables/hoses through.
coyoteboy
Postby built2run » Sat Apr 16, 2011 11:53 pm
ver very interesting info man, i mus give u props
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Postby coyoteboy » Sun Apr 17, 2011 10:00 pm
Pic
coyoteboy
Postby coyoteboy » Fri Apr 13, 2012 1:40 pm
Just a little non-scientific FYI on this, since fitting it I've never had the CC water temp higher than body temp at any time. Pump on constant and fan temp controlled.
coyoteboy
Postby Corey » Fri Apr 13, 2012 3:47 pm
Thanks for the update, good info :)
Corey
Images: 50
Postby underscore » Fri Apr 13, 2012 4:29 pm
so you're using this are the front cooler for the WTA intercooler?
Postby coyoteboy » Sat Apr 14, 2012 11:43 pm
Yep, stock CS/RC top core, stock pump, new hoses and this radiator. Spal 10" pusher in front of this rad.
coyoteboy
Postby michicop » Mon Feb 04, 2013 7:02 pm
Do you have more details about the radiator? Which my, engine etc...
Sounds like a great upgrade!
michicop
Postby coyoteboy » Mon Feb 04, 2013 9:01 pm
Hi,
It's this one:
http://www.a1radiators.net.nz/products/audi/audi_100
(Going by the dimensions, I've lost the details of the original purchase).
HTH
coyoteboy
Postby michicop » Tue Feb 05, 2013 5:19 am
Thanks mate!
michicop
Postby michicop » Fri Sep 06, 2013 10:04 am
http://item.mobileweb.ebay.at/viewitem? ... 0383047143
Just to be sure, is this the correct one?
michicop
