The first thing to increase boost is some sort of boost controller electronic or manual will accomplish the same thing.
A boost cut defender is also a must if you plan on retaining a stock ECU and boosting past 10 psi. Basically the stock ECU will cut fuel if it detects anything beyond 10psi of boost. Some opt to simply disconnect the turbo pressure sensor, but this completely disables a useful safeguard IMHO. A boost cut defender device will allow you to increase boost levels, to say 15 psi without hitting boost cut, but say you blow out your wastegate controller line and you over boost to 16psi, the fuel cut function will still work to save your engine from damage.
I am totally pushing my product here, but I can make you a plug n play boost cut defender for less than half the price of any commercially available product. And its the only plug and play option that is available. PM me if you want more info
