Thanks for the fast shipping Aaron.
Man I just tried installing the said adaptor onto my car today and what can I say? It's a bitch to work with if you don't have the right setup as what ATS made it for. The wastegate tube that goes down from the adapter sits side to side with the stock banjo bolt(so close together you can't loosen it or tighten anymore) and it's also hitting my oil return hose(which I think is the culprit for not letting me bolt up this whole thing together nice and tight). A little trimming of the stock fan shroud needed as well for the t3/t04e turbo. Got everything on there and something isn't letting the turbo manifold sitting flush against the block so I have a huge exhaust leak. Downpipe that came with my turbo kit will now have to be refabbed up to make it fit with the exhaust system. Talking about getting myself into more shit. I'm thinking about getting rid of everything and start all over. Probably go with a td06sh turbo kit that bolts right on. Although if you have any offers on a trade Aaron I'd happily listen to what you have to offer if I send everything in for a bolt on turbo kit? Yeah I know I'm dreaming...turbo kit I have now is from an mr2 so pretty much it will bolt right up to an mr2. I may just end up selling it
Garrett T3/T04E Ballistic turbo, Stage 3 turbine, 60-1 trim wheel, .63 ar with a turbonetic iron cast manifold. Turbonetics Deltagate II external wastegate w/ 2 1/2" custom dp. Includes all oil lines and fittings. Wastegate routed back into dp.
To you guys that are DIYer's like me, please don't buy things like this expecting to make it work with your particular setup without needing to spend more money.
