Okay so I noticed the ST205 IC core has a hose connector on the back of it which appears roughly the same size as the one on the back of the manifold on my ST185 (not visible in the picture). Is the functionality meant to be the same or is it there for some other purpose? Could I use it to send pressure to my EBC sensor and boost gauge? or should I just cap it and stick to using the one on the back of the manifold? Or, is there another use entirely that this was intended for?
Also, is it detrimental to have many feet of vacuum tubing in the boost controller circuit? I have the EBC stashed behind the rear intercooler bracket, so hoses run from the turbo to the back of the engine, through the boost controller solenoid, and back to the wastegate actuator in front. I'm wondering if I should be concerned about a delay in wastegate actuation causing pressures to spike and exceed safe levels.
