Oil Filter Relocation
If you're taking the A/C out that looks like a great place to put it. Take care routing the lines since the exhaust and serpentine belt are in close proximity, I wasn't careful enough and had a line rub on the alternator pulley which made a bit of a mess. Luckily I caught it right away so very little oil was lost and no damage was done.
FC Zach
This is something I've been considering as well but I have and plan on keeping my ABS and AC so space and options are limited for me. . I assume.
You might be able to have the filter up somewhere in the front bumper, I can't remember which passthroughs have A/C lines running through them though. If you're staying on the pavement you could run the lines under the lower rad support.
