Go Fast Bits Diverter Valve installed!
jgtfour
Member
grip-addict
Active member
how's it sound ? is it pretty quiet or do you get to hear some flutter?
I recirc'd my hks bov on my '90 that had the afm. it made a HUGE difference in driveability and shifting smoothness. really dug it.
but, kinda hard to hook up a duck call when your car's not blowing any air to atmo, ya know? :)
jgtfour
Member
It’s pretty quiet. It sounds stock aside from having an open intake filter. I still have the first generation HKS SSQV with the recirculating kit but that thing is huge compared to the GFB DV. I just wanted to try something different and low key. I’m happy with the setup. I do miss the venting sound!
Awesome!
My setup is similar to yours.
Here's how I set mine up...
There is a dial in the cabin that I can rotate and choose how much to vent to atmosphere or recirc.
Works very nice!
GoFast Bits: Part No: T9525. Deceptor Pro II TMS Universal (25mm inlet- 25mm outlet) motorized Blow off valve or BOV.
https://hpsperformanceproducts.com/
HPS 2-1/8" ID, 1" ID Branch, Silicone T Hose Coupler Hose Adapter, PN: 212-THOSE-100-BLK
HPS 2.75" ID x 3" Long Silicone Straight Coupler Hose (70mm ID x 76mm Length) PN: HTSC-275-BLK
HPS 2.75" > 3-1/8" ID x 3" Long Silicone Reducer Coupler Hose (70mm > 80mm ID x 76mm Length) PN: HTSR-275-312-BLK HPS 2-3/4" (70mm) OD, 70 Degree Bend 6061 Aluminum Elbow Tubing, 2-3/4" CLR, 16 Gauge PN: AT70-275-CLR-275
HPS High Temp 3-1/8" ID x 3" Long Silicone Straight Coupler Hose (80mm ID x 76mm Length) PN: HTSC-312-BLK
HPS High Temp 1" ID Silicone 90 Degree Elbow Coupler Hose (25mm ID) PN: HTSEC90-100-BLK
HPS Stainless Steel Embossed Hose Clamps SAE # 48 - Effective Range: 2-3/4" - 3-1/2" (70mm-90mm) | Pack of 2 EMSC-70-90x2
1” Hose Barb Nipple Weld On Aluminum Bung Fitting
https://www.ebay.com/itm/273388079515
I cut the aluminum elbow and welded the Bung in.
autojumbled
New member
What a great solution - thanks for sharing.
I am not at all happy with the HKS SSQV on my ST185. Its very bulky and doesn't really have a decent home in the engine bay. I'd also much rather have a recirc system in place given all the stories I hear about BOVs causing issues.
Didn't know about those self-sealing silicone joiners - going on my future mods list
Active member
Way back when on my second Alltrac I used to have a Samco T hose and the Fensport dump valve.
I loved the way it sounded.
I miss hearing that. I miss driving the car even more......
Top
