Aquamist HFS4-v3.1 Install, ST165
Re: Aquamist HFS4-v3.1 Install, ST165
Postby underscore » Fri Aug 14, 2020 10:36 pm
Nice write up! I had a bung added to my intercooler but never ended up putting the system in, I assume it makes a big difference with the smaller 165 intercooler running that kind of pressure.
Postby mickeyfinn » Fri Aug 14, 2020 10:53 pm
Thanks!
Heck Yeah! The whole reason is because of the ST165 Intercooler.
I really underestimated how poor the thing really is.
I don’t really want to bend and fabricate a bunch for a FMIC.
I have an ST205 Intercooler. No way it’s going without a bunch of cutting either.
I figured I’d give this a try.
Which Intercooler did you have that bung welded in?
I had a hard time finding any information on the Aquamist. So I figured I share what I know.
So many people have helped me here.
I hope it’s helpful to someone else.
mickeyfinn
Postby underscore » Sat Aug 15, 2020 5:36 am
I had it welded into my stock RC WTA intercooler. I went for the same spot as you, as far away from the TB as I could get. Unfortunately the nozzle fouled on the timing belt snorkel and the 90* adapter I needed to make it work is discontinued so I put a plug in the bung and sold the kit.
Postby Gert » Fri Aug 21, 2020 6:00 am
Aquamist, good choice. I have an ERL System 2 kit in my car since 2001. Never had any (serious) malfunction issues.
Gert
Postby mickeyfinn » Mon Sep 14, 2020 8:17 pm
I've got everything wired up now... going through the pre-start checklist..
According to the manual:
Step 4.
Start the engine and let it idle for a minute or so:
- The green LED on the controller should flicker. The
flicker should speed up with engine speed. If the system
behaves as stated above, you have successfully
wired up the HFS-4!
I'm not seeing this. Somehow the Aquamist controller is not reading the Injector Duty Cycle.
The green wire (in the Aquamist RJ48 grey harness) is for sure connected to Fuel Injector #1 in the Car ECU harness.
I cut the wire, and reconnected them, just to make sure the green wire is indeed tapped into FI #1.
Not sure why it's not working.
I'm at a standstill until I get this resolved. I reached out to Aquamist to see if they have any ideas.
mickeyfinn
