aftermarket fan pairing with mishimoto radiator
Postby grip-addict » Thu Apr 22, 2021 7:49 pm
hiya,
I'm running a mishimoto radiator and had to switch to their slimline fan since the stock fan/shroud doesn't fit.
I'm battling overheating issues at stoplights/idle and the mishi slim fan does not appear to be keeping up.
Has anyone else run this radiator with an aftermarket fan successfully? What did you use if so? :)
grip-addict
Re: aftermarket fan pairing with mishimoto radiator
Postby abeans » Thu Apr 22, 2021 10:01 pm
SPAL 30101522 in OEM location.
1990 St185 Celica
abeans
Postby grip-addict » Fri Apr 23, 2021 12:26 am
Thanks. Are you getting by with just 1 and no shroud?
grip-addict
Postby abeans » Fri Apr 23, 2021 12:47 am
Yeah, no shroud and just the one on the drivers side.
I have a pusher i might add to the other side as well, but it hasn't needed it.
1990 St185 Celica
abeans
Postby grip-addict » Fri Apr 23, 2021 3:27 am
thanks, i'll give it a go with a SPAL. I've been thinking about switching the fan with the Haltech anyways, so this is a good excuse to run a new wire :)
I might see if I can convert the mishi fan to be a pusher and swap it to the other side of the radiator. The AC condenser is still in place though, so I might need to get creative :wink:
grip-addict
Postby FC Zach » Mon Apr 26, 2021 11:15 am
grip-addict wrote:Thanks. Are you getting by with just 1 and no shroud?
+1 for a Spal fan. . . I'm not necessarily using a shroud but I did have some mounting tabs made so that I could space the fan off the rad a bit to add foam between the rad and fan. All this because I despise those push-through zip-ties. Also notice. . I reused the OE connector so it's plug and play.
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby abeans » Mon Apr 26, 2021 12:15 pm
I used these for mounting https://www.speedwaymotors.com/SPAL-Fan ... ,5549.html
and
https://www.amazon.com/Spal-30130013-Fa ... B009OBP51A
I actually talked with one of the SPAL guys at PRI he recommended the metal through the rad mounting. The plastic ones torque too much.
1990 St185 Celica
abeans
Postby underscore » Mon Apr 26, 2021 2:22 pm
I used a no-name fan with an ASI rad and had no issues, even in the middle of the summer (40*C and higher).
Postby Alikazam » Fri Apr 30, 2021 7:42 am
I run a single 11" high flow spal fan on my eBay radiator. No issues. Highest temp recorded daily driving in traffic etc so far since March is 212F. Mostly stays under 200. The JB weld is holding up just fine!
1990 Celica Alltrac - Emma
Gen 3 engine
KO Racing Street Brawler - Precision 5130 Turbo
KO Racing In Factory ECU Case - Link G4x ECU
327 AWHP @ 18psi - pump gas
Alikazam
Postby alltracman78 » Thu May 06, 2021 3:39 pm
Damn that looks nice!
I have one of these radiators I need to put in my car one of these days.....
Postby FC Zach » Thu May 06, 2021 4:02 pm
alltracman78 wrote:Damn that looks nice!
Thank you! My fabricator friend does great work.
1993 Yamaha GTS1000
FC Zach
Images: 9
