Manual boost controller
Postby busdriver » Thu Aug 26, 2004 9:04 pm
Which MBC's work well? I found a couple that sound nice, but would like to hear what everyone else is using. Here are the links to a couple of them.
http://www.horsepowerhq.com/HTML/DSM/access.htm
http://www.dawesdevices.com/boost.html
on a sidenote, does anyone know where I can get some of that nylon tubing for a mechanical boost gauge?
Jake
90 st185
needs tlc
busdriver
Postby toayoztan » Thu Aug 26, 2004 10:27 pm
Make your own..it's very easy, and very cheap. And they work just as great as any mbc you will buy, if not better. The ones you might buy (i haven't looked at your links) might have a bleeder valve on it. Usually, this will cause boost spikes unless you are boosting a pretty good amount. I suggest to just spend 15 bucks (can get them all from Ace Hardware) on parts, build it yourself, and don't drill a hole where a bleeder valve would usually be. There are links floating out there on how to make your own...hopefully someone can give a few.
But, to be considerate, i went ahead and looked at those links. They both look good, as neither suggests a bleeder type. The one from hphq looks exactly like mine...and mine's cheaper :wink:
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: Manual boost controller
Postby Gary » Fri Aug 27, 2004 4:12 am
busdriver wrote:on a sidenote, does anyone know where I can get some of that nylon tubing for a mechanical boost gauge?
If you want an online shop, $4.99 from Lotek.
http://www.gaugepods.com/gaugegear.html
You might found one at your local part stores.
93 ST185
Gary
Postby busdriver » Fri Aug 27, 2004 5:50 am
I thought about making my own, but wasn't sure if there was a quality difference. Thanks for the responses.
Jake
90 st185
needs tlc
busdriver
Postby gormenghast » Sat Aug 28, 2004 1:37 am
i just bought a MBC from twosrus.com. I have heard nothing but great things about it so i can wait to get it in. it was 53 shipped. i think you should check it out. they also have other great stuff for our cars. :wink:
90 All-Trac - Red
91 MR2 Turbo - Red
gormenghast
