FS : 1994 JDM celica st-205
Any country, GT-Four for sale or parts
Postby DWS » Fri Jul 16, 2010 3:05 am
Toyota Célica GT-FOUR 1994 3SGTE Version 3
color White
This post is for a JDM GT-four so check the regulation in your place before purchase
This is the list of mods on my car because last year i got fire in the engine bay.
The reason : bad compression on piston 4 (50psi) so the oil dip stick pop out and the oil go on the turbo
oil + heat = fire :doh:
so i fully rebuilt the engine
Wiseco forged piston with side coating ,05 oversize 9:1
Rod Bearing ACL série Race
Crank Bearing ACL série Race (1 step over size)
Short Block fully balanced
Main Pully (crank) in aluminium, and blanced
Clutch 6 puck With spring
Flywheel OEM resurfaced and balanced
fully rebuilt pressure plate
Block and head planed
Stud ARP
head gasket Apexi
ignition wires Magnecor KV85 COMPETITION 8,5 mm
Spark PLugs NGK R
Cap and Rotor OEM Toyota
Gaz filter OEM Toyota
Seals Valves (intake et exaust) OEM Toyota
ALL other engine Gaskets or seals OEM Toyota
Water Pump OEM Toyota
Timing Belts, bearing OEM Toyota
Oil pump OEM rebuilt
Turbo rebuilt with oem parts (ct20B)
All fluides are new
Trany Oil GL-5 Syhth.
Thermostat OEM Toyota
Prestone OEM Toyota
alt. Fully rebuilt
Big 3 (4 ga wire between alt, bat, fuse box and starter)
Alpine Radio
4 Winter Tire Toyo Garit KX
4 summer tire Yokohama (from Japan)
Brakes are still good
Price $14 500 Ne
go. (can)
both front fender in front have small scratch (picture come later)
give me your info via pm and i will contact you
i'm from Quebec ( Montreal Area)
DWS
Re: FS : 1994 JDM celica st-205
Postby Sal » Sat Oct 16, 2010 4:26 am
Good luck with that sale... She's a beauty. Any way you would you sell me that rear visor?
'94 ST205 GT-FOUR WRC
13.3 @ 101MPH
Sal
Postby banshee 101 » Thu Mar 10, 2011 11:41 pm
is it plated in quebec???
beautiful car by the way
91 ST185 JDM
w/ Mods
banshee 101
Postby DWS » Fri Mar 11, 2011 1:12 am
sorry long time witout coming here, the car is sale, and yes is one of the rarest fully legal in quebec...
admin please close topic
DWS
DWS
Return to Global For Sale/Wanted
