The ST185 wheel size thread (offsets, widths, etc)
Re: The ST185 wheel size thread (offsets, widths, etc)
Postby lalojamesliz1 » Wed Feb 28, 2018 8:59 pm
FC Zach wrote:So you want proper offsets front and rear to do without your spacers? Are you widebody? What about the wheel width? And are you wanting to stay 7" wide all around or are you wanting them staggered?
Is it possible without spacers? I just want to be able to do a proper tire rotation to get the best tire life so I didn't want to go staggered I was thinking 8" wheels but whatever fits at the best offset.
Aren't all st185's widebody?
91 Celica all-trac gen3 swap (small-med $$$ sponge)
69 mustang 408w (large $$$ sponge)
08 sequoia 5.7L
14 avalon
02 taco dbl cab V6 turd
and a 2 car garage :shoots:
lalojamesliz1
Postby underscore » Thu Mar 01, 2018 4:38 am
Not all 185's are widebody, some are narrowbody. For a widebody the rears will sit 1" in from the fenders compared to the fronts if the wheels have the same specs.
Postby FC Zach » Thu Mar 01, 2018 7:44 am
lalojamesliz1 wrote:Is it possible without spacers?
Sure but the problem you'll run into is finding a wheel that you like with the specs you want. . . You could always do bespoke wheels (like CCW) but that's a bit of money that route.
lalojamesliz1 wrote:I just want to be able to do a proper tire rotation to get the best tire life so I didn't want to go staggered I was thinking 8" wheels but whatever fits at the best offset.
In this case (for practical reasons), I would select a width and offset to suite the front and keep a spacer/adapter for the rear to compensate for the extra body width.
lalojamesliz1 wrote:Aren't all st185's widebody?
What ^he said :)
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby lalojamesliz1 » Fri Mar 02, 2018 4:54 am
Let's just say I got spacers for the rear.... What size spacers and wheel offset do you guys think would look decent? I'm thinking of selling my 87 yota pickup and I'm getting some cash from some things but I can't spend a lot on wheels and tires. bills and stuff :(
I'm tempted to just get tires but I need something different and so I can have more tire options
17x8 with 35 offset sould be ok right? I get worried the tires will rub if I have rear passengers and I go over a bump or jump the car :)
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby 93celicaconv » Mon May 27, 2019 11:14 am
Old thread, but just thought I would post what my son has on one of his All-Tracs - and everything fits and looks great:
- Wheels: Compomotive TH1781, 17x8.0 size, 5x100 bolt hole pattern, 35mm offset
- Tires: Michelin Pilot Sport A/S 3+, 245/40ZR17
- Spacers: H&R 3025541, 15mm thickness, 5x100 bolt hole pattern (for rear only)
Clears the factory rear strut and no issue with the fender opening.
93celicaconv
Images: 26
Postby Mr Alltrac » Fri Jul 12, 2019 6:33 pm
By chance would a 18x9.5 +38 offset fit on a 1990 alltrac?
Mix up with companies when ordered and I have 2 sets of gramlight 57dr. There a perfect offset for my brz but was wondering if they would fit my alltrac before I send back the other set.
Mr Alltrac
Postby 93celicaconv » Fri Jul 12, 2019 6:38 pm
What's the bolt hole pattern on them? Also, what size tires are you thinking? No doubt you will need spacers. I think your width of the wheel (9") would require a pretty wide tire, and with the amount of spacer width you'll need, you will be out beyond your rear quarter fender roll lip wheel opening.
93celicaconv
Images: 26
Postby Mr Alltrac » Fri Jul 12, 2019 8:05 pm
5x100 lug pattern.
On the 9.5" wheel I'm gonna run 245 on my brz. So I figured the same size tire since it would be a little bit of a stretch but not the stance look.
Mr Alltrac
Postby 93celicaconv » Fri Jul 12, 2019 11:50 pm
Mr Alltrac wrote:5x100 lug pattern.
P245/xxR18: What are the "xx"? That is pretty important to understand tire diameter.
93celicaconv
Images: 26
Postby Mr Alltrac » Fri Jul 12, 2019 11:52 pm
Sorry thought I posted that. 245/35 r18
Mr Alltrac
Postby 93celicaconv » Sat Jul 13, 2019 12:08 am
Mr Alltrac wrote:Sorry thought I posted that. 245/35 r18
I don't see where you did. Anyway, the tire size my son put on his has a tread width of 8.4" and a section width of 9.8", and a diameter of 24.7". They just miss the rear struts and are just inside the rear quarter wheel openings with the 15mm spacers - just barely.
Your 245/35R18's have a tread width of 8.8", a section width of 9.8", and a 24.8" diameter. I think your diameter will be fine - technically. That tire is pretty close on section width and diameter to my son's tires. The wheel offsets are pretty close to each other too. So a 15mm spacer for the rear wheels should work out for you, and nothing needed on the fronts, and you should just squeak by relative to strut clearance and fender wheel well lip clearance - I think (and just barely). My thoughts anyway.
93celicaconv
Images: 26
Postby Mr Alltrac » Sat Jul 13, 2019 1:37 am
Yeah I didn't post it but I thought I did lol
So in theory it works. I may just wait and try to bolt on the wheels from my brz on after the tires are mounted.
If It clears I'll keep them if not I'll send them back and get a 17x9 wheel setup.
Mr Alltrac
Postby Alikazam » Sat Feb 01, 2020 5:21 am
93celicaconv wrote:Old thread, but just thought I would post what my son has on one of his All-Tracs - and everything fits and looks great:
Great info! Thanks for posting.
Alikazam
Postby MARLON1211 » Mon Feb 03, 2020 6:59 pm
Heres OZ Cronos 17X8 35et w/ 1" rear spacers
My opinion perfect set up for our cars.
https://img.photobucket.com/albums/v518 ... 4el0op.jpg
SO BE IT
MARLON1211
Postby abraxxa » Mon Feb 03, 2020 8:48 pm
Same here on my ST205, OZ Cronos are just gorgeous!
facelift ST205
abraxxa
