Replacing brake hose brackets on front struts
Postby Domspun » Sun Sep 06, 2020 1:30 pm
Since they only sell inserts for the front struts, I am stuck with rusty lowers. Now the brake hose bracket rusted out and is broken. Anybody replaced those? I guess I'll need to get them fabricated!?
Domspun
Re: Replacing brake hose brackets on front struts
Postby Domspun » Sat Sep 12, 2020 12:08 pm
No idea, anybody?
Domspun
Postby underscore » Sat Sep 12, 2020 2:01 pm
You could get a new set of housings from a junkyard 5th gen? They all use the same one. Otherwise you'll need to do skmething custom.
Postby Domspun » Wed Sep 16, 2020 11:09 pm
Trying to find a rust free pair is tough. Saw one strut on Yahoo Auction Japan that was rust free... only one.
Domspun
Postby abeans » Thu Sep 17, 2020 12:05 am
You talking about the bracket that bolts to the strut for the ABS and Brake line?
abeans
Postby underscore » Thu Sep 17, 2020 2:12 am
Try using car-part or Row52 to search wreckers out west, the strut housings will be in much better shape.
Postby Domspun » Sat Sep 19, 2020 3:21 pm
abeans wrote:You talking about the bracket that bolts to the strut for the ABS and Brake line?
The one for the brake line.
Domspun
Postby abeans » Sat Sep 19, 2020 3:35 pm
I can't picture it. But if there is enough demand I can probably get them reproduced in some form of high strength plastic
abeans
Postby Domspun » Sun Sep 20, 2020 3:08 pm
The metal tab that sicks out the strut where the brake hose go trough. My hoses are held by tie-wraps.
Domspun
Users browsing this forum: No registered users and 6 guests
