Koni Yellow adjustables, Moroso 550lb spring up front and 400 Eibach in the rear (coilover conversion with cut perches), Whiteline adj, rear sway bar, 1.8 neg camber front with 1/8 inch toe out, rear is .8 neg and 1/8 toe in.....poly bushings...
Brakes are Wilwood (4-pot with 1.75" diameter pistons..)
Street: 17x7.5 Motegi MR12 with 225 45 17 tires...(soon to be RoJA 17x7)
Autocross: 17x9 Sportmaxwheels with 275-40-17 Hoosiers...
