Brake options
Postby Griffin » Mon Oct 04, 2004 5:39 am
furpo wrote:that is what i suspected. i have a written off non abs gt4 sitting on my front lawn at the moment. are there any differences between the abs and non abs brake systems other than the pipes, abs box and abs computer?
roger
The proportioning valve may be different, as may the master cylinder - I don't know for sure though.
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby maroon_185 » Thu Oct 07, 2004 2:25 am
what about the slotted and dimpled rotors on 935, I want slotted but want the look of crossdrilled also at the same time with out the possibility of cracking , so say would the dimple really hurt anything in your guys opinon
Chris Fowler
1990 maroon 185 (rc swapped)
1991 red mr2 (3s swap coming soon) Dads
maroon_185
Postby AWDios » Thu Oct 07, 2004 2:26 pm
Not as bad as drilled, but it's still creating a weakness. Like was stated before, if this is just a street aplication, I wouldn't worry about it too much because you just won't be putting the same stress on the rotor.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby SBCelicaGT » Tue Oct 12, 2004 7:59 pm
roger
90-93 Celica Alltracs have 15/16" bore MC w/o ABS and 1" if you have ABS.
Adrian Avgerinos
90 Celica GT-V6
SBCelicaGT
Postby furpo » Wed Oct 13, 2004 6:08 pm
thanks for that. ill stick with the abs master cylinder. is there any difference in the caliper piston size?
roger
furpo
Postby SBCelicaGT » Wed Oct 13, 2004 6:39 pm
Not that I know of. I have a set of Alltrac calipers that match the set of GT-S calipers. 50mm fronts and 35 mm rears. Anyone with an ABS car can measure theirs to verify, but I doubt it.
Adrian Avgerinos
90 Celica GT-V6
SBCelicaGT
Postby alltracman78 » Mon Oct 18, 2004 1:27 am
Calipers are the same, but the porportioning valve is different.
Only the front lines are different. Rears are the same.
*One other factor, do the 184s/185s have the same brake porportion? If not, changing to a 184 non-abs porportioning valve will change the front/rear bias. Not sure how much it matters tho :shrug: *
