Giving the alltrac better road feel
New member
I haven't read through the 5 pages , but jut in case no one else has mentioned it...
CASTER!!!
Caster has a huge effect on steering & car feel.
I run about 4deg and want more. It along with larger sway bars, stiffer springs, decent tyres and poly bushes has made a huge difference.
New member
I turned my adj strut tops 90deg to get the caster adjustment.
I need coilovers and custom strut tops to get more than the 4deg I have now.
I dialed in more camber with crash bolts.
athousandleaves
New member
I swapped & rotated the strut tops on my teins and it totally screwed my kingpin so once I got more than 1.5ish of a way into a turn the wheel would go to full lock and not recenter without me pulling it back :roll:
New member
Did you get it wheel aligned after doing the swap & rotate?
Adjusting caster (or camber) throws out your toe settings, so you always need a wheel align after.
Active member
What tires size are you running? Any rubbing from that much caster?
New member
225/45/17, and they have plenty of room (on +39 offset wheels though :( ).
Adding caster doesnt effect tyre position when the wheels are straight ahead.
It only only effects position slightly during turning (tyre moves towards the back of the car a fraction).
rio_cyber
New member
btw dont mr2 ps pump have all mamo yumbo needet , valves stuff electronic controlers,,, and so on, to function properly alone,,, thats why the are very popular in EV world afaik...
New member
They are popular because the PS Pump is powered by an electric motor, not the engine.
Besides that, the power steering system is no different to what we have.
Top
