Dual piston brakes
Dual piston brakes
Postby toronto4wd » Fri Oct 15, 2004 10:40 am
I have a dual piston brake set up on my 1991 ST185 front clip and was wondering if I could swap that in to my 1992 ST185? Any issues? Are pads an issue?
Lorenzo V
1992 ST185
Toronto, Canada
toronto4wd
Postby alltracman78 » Fri Oct 15, 2004 1:57 pm
Swap it and see....
Brakes are pretty easy, so it shouldn't take long to see if they fit. Pads might not work though.
Postby NemesisGT-2 » Sun Oct 17, 2004 3:20 am
I've had these on my GT-2 for over a year now, and i really like them. They seem to have a very good initial bite compared to the stock brakes (although this could be due to the pads). They do seem to fade a little more quickly due to the smaller rotor diameter, but it isn't too bad. The one thing that kind of sucks is that I haven't been able to find replacement pads for it anywhere in North America. Fensport at least used to sell the pads for them, but I think they were around $85 for just basic pads. I was going to convert back to the single pot calipers until i got my All-Trac last weekend which needs a new set of rotors, so i'm gonna hold off on the conversion and decide what I want to do this spring. If you do find a place to buy pads on this side of the Atlantic, please let me know. MR-2T pads from one of the years MAY fit, but i haven't been able to get ahold of any to test this theory yet.
Ben
1991 Celica All-Trac
1992 Celica GT w/1990 3S-GTE
NemesisGT-2
Postby roo » Tue Oct 19, 2004 11:33 pm
top secret and endless both have high performance pads for that dual piston setup for around $100 a set.
roo
Postby Kyoto » Sat Oct 23, 2004 9:25 am
Not strictly a dual piston question, but rather than start another thread i thought i'd use this one.
How much fabrication is involved in getting the 205 brake setup to fit the 165? Was just looking at TRDs website and those grooved discs look mighty fine...
Tim // Melbourne, Australia
1986 ST165. 152,000km on chassis
ST205 WRC engine / IC system / rear LSD with 82,000km
Blitz K1-380V
Apexi Power FC
Aussie 3" dump pipe to 3" catback system
TWM short shifter.
Whiteline front strut brace
Kyoto
