stock struts on lower st185
Postby 903SGTE » Thu Nov 04, 2004 12:42 am
anyone used eibach lowering springs?how are they for the st185?
903SGTE
Postby 935motorsports » Thu Nov 04, 2004 3:38 am
I have seen some using. They are too weak for the all trac and cause an extreme lowering.
I'd suggest B+G which are made in a similar fashion to Eibach but with a better spring rate.
935motorsports
Postby 903SGTE » Thu Nov 04, 2004 10:14 am
how much do they lower the all trac and how hard of a ride are they?ive had eibach in my 88 gts and was happy with the ride quality.just want to make sure its not a harsh ride??anyone else have any lower spring suggestions??
903SGTE
Postby RIalltrac » Thu Nov 04, 2004 2:36 pm
If I remember correctly ground control uses eibach springs, they can custom wind them for you depending on what rates/drop you want. Probably your best option if your looking to have a certain type of ride. I remember someone saying that you can actually call them up and run through want you want in your spring and they can suggest the proper rates and go from there.
Chris - 90 ST185
RIalltrac
Images: 2
Yeah
Postby MARLON1211 » Thu Nov 04, 2004 3:11 pm
hows Ground control really i've been hearing about them, and i would like to just do a mild upgrade like that. Anybody did the same. I thought about that using a new OEM with GControl Coilover springs. Anyone?
SO BE IT
MARLON1211
Postby 903SGTE » Thu Nov 04, 2004 11:39 pm
anyone used the b+g springs?how are they??
903SGTE
Postby alltracman78 » Mon Nov 08, 2004 11:29 pm
As far as struts, if you're looking at GTS ones, KYB makes them for the GTS, and if I remember correctly they were ~ $100 5 yrs ago.
Postby TraviST185 » Thu Nov 11, 2004 5:13 am
I am selling some of my whiteline parts:
http://www.alltrac.net/phpBB2/viewtopic.php?t=2437
Travis Hanson
TraviST185
