The ST205 wheel size thread (offsets, widths, etc)
Postby Toxygene » Fri Aug 21, 2009 7:04 am
Seeing as ST205s are now entering North America I believe it's about time we start this thread.
So what's the widest wheels that will fit on an ST205 with minimal modifications to the fenders? Minimal meaning just fender rolling. Also, what is the perfect offset for the wheels to fit flush at the same time as being as wide as possible?
Please post pictures of your examples along with as much information about the wheels as possible. If you are taking pictures for this thread, then try to take not only side shots of the car but pictures from the front or rear showing how far or close the wheels are to being flush with the fenders. Please include info such as the offset of the wheels, the size and width and of course the make and model of the wheel as well.
Toxygene
Postby ~CDUB~ » Fri Aug 21, 2009 11:21 pm
heres my st205 with oz wheels 16x7 38 offset with 235/50/16 fits perfect doesnt rub. Car is lowered slightly on Cusco Coilovers.
as well i did throw my volk TE37 17x7.5 40et with 245/40/17 on it and they fit very well although i didnt actually drive anywhere with them on this car or take any pictures.
Im not running any spacers.
~CDUB~
Postby Insanity-74 » Mon Aug 24, 2009 3:44 pm
Widest wheels you`ll fit without problems is 9" although I wouldnt go above 8.5"
Biggest advisable size is 18" although 19s will fit they can catch the arches.
on 18" wheels 225/40/18 is the best size and will fit without catching
Offset depends on spoke pattern, ET35 is recommended....ET38 will fit on some alloy wheels..beyond that your taking a big risk of the wheels catching the front calipers. ET 30 and smaller will fit but may look a bit odd or stick out too far, again catching the arches when going over bumps.
Insanity-74
Postby Toxygene » Tue Nov 03, 2009 4:54 pm
Anyone else have some pictures of their wheel setups on their ST205s?
Toxygene
Postby jackett » Tue Nov 03, 2009 9:21 pm
Here you go. Compomotive MO 17x8 et35 front et20 rear:
jackett
Postby T-Barr » Tue Nov 03, 2009 11:33 pm
I run these 17x7.5 on 215/45/17 tires
These are knock offs of a pretty awesome rim.
[/img]
Keep it simple, Keep it stock =)
94 GT four ST-205 - Summer car
T-Barr
Postby Meurz » Wed Nov 04, 2009 8:48 pm
Looks like a genuine WedsSport SA90 to me?
Turbocelica.nl
Meurz
Postby abraxxa » Wed Nov 11, 2009 9:52 pm
Dotz Daytona 18x7.5J ET-35 225/35/18 Goodyear Eagle F1 with 15mm rear spacers:
8 or even 8.5J would be better as well as more sidewall.
The Dotz weren't available any wider and the 225/40/18 tires wouldn't have been registerable here in Austria. :bangshead:
facelift ST205
abraxxa
Postby Toxygene » Thu Nov 12, 2009 4:34 am
There is a group buy for Volk Racing TE37s in any size, width and offset.
If you all can come up with a size, width, and offset that will fit flush and maximize your grip then you can start a group buy for a TE37 wheel with your particular specs.
Get in touch with Kami Speed: http://alltrac.net/phpBB2/viewtopic.php?t=36026
Toxygene
Postby TEAMFaint » Sat Nov 21, 2009 1:34 am
I`m torn on what to do for rims on the 205.
Currently running 18x8 +35 offset OZ WRC Rally rims (the multi spoked).
Pictures to come on sunday.
Unsure what to do come spring time.
current project: 94 st205
TEAMFaint
Postby Toxygene » Sat Nov 21, 2009 3:53 am
TEAMFaint wrote:I`m torn on what to do for rims on the 205.
Would you be interested in our Volk TE37 group buy?
Toxygene
Postby TEAMFaint » Sat Nov 21, 2009 4:13 am
If I had 3000 to drop on wheels yes, unfortunately I do not :(
TEAMFaint
Postby Toxygene » Sat Nov 21, 2009 11:48 am
I don't think they came out quite that expensive.
Toxygene
Postby schmooot » Tue Dec 01, 2009 2:39 pm
I just ran a test fit of 7th gen gts wheels 16", it clears the calipers on the sides same as the stock wheels but I'll need a 10mm spacer to clear the front. That would be in relation to sitting facing the studs not the car.
Either way, what are spacers generally made out of? aluminum?
I've got a master machinist friend who can make me up some very high precision/quality ones for a fraction of the cost of new ones, then I just have to buy some longer studs
schmooot
Postby schmooot » Sat Dec 12, 2009 7:26 am
update. 7th gen gts wheels will fit, the are 16X6.5 ET38.
I had some scrap aluminum lying around it was 3.14mm thick so I made up 3 plates just to test fit the wheels on the car (for a total space of 9.5mm roughly).
The fronts seem to sit flush with the fender, quite tight on the caliper but it does clear...remember these spacers add up to 9.45mm roughly, I'm going to get 12mm ones made up for the front
The rears are quite sunk in as you can see, maybe down the road I'll get up to 25mm but as for now I'm going to go with 15mm and just get longer studs, lots of clearance on the calipers on this end
The lugs just barely go on right now so I will be getting longer studs for the setup
I'll be getting a machine shop to make up the spacers as it will be much cheaper than what I can buy anywhere else, and they have all winter to do it so I guess I'll post pics once all is said and done
schmooot
