i just did the strut conversion for the rear of my 88 and have a problem... the stock mount has a smaller diameter hole than the replacment AGX struts. they didn't fit so i drilled it out to the proper size. Only poblem is that the strut doesn't catch on the mount so i can tighten the bolt on top!! anyone run into this problem? and how did you resolve it?
thanks
thanks
