Longer wheel studs
Longer wheel studs
Postby woot woot » Tue Sep 18, 2012 3:18 am
Hey guys just a quick one. Wana put some 5mm spacers on my 40 offset Oz chrono wheels to make them 35 offset. DO i need to run longer wheel studs so the nut has more thread to grab on to?
There are hub centric and the centre hole is 54.1mm is this correct for the car. I thin kit was but wana make sure
And are th wheel studs M12x1.5? As i might get new nuts also
I have a JDM narrow body 185
Cheers
Jo
woot woot
Re: Longer wheel studs
Postby athousandleaves » Tue Sep 18, 2012 5:30 am
Yes they're M12x5 and you will need longer studs.
Go for the ARP extended studs #100-7715 or OEM Toyota Landcruiser studs as they're longer from the factory.
Also; try searching next time please.
viewtopic.php?f=24&t=40283
viewtopic.php?f=10&t=29508 <- ST165's use ARP #100-7718
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby Killtodie » Tue Sep 18, 2012 5:42 am
http://www.ebay.com/itm/ARP-Toyota-Supr ... 2e&vxp=mtr
^^ these are the ones I bought. You will need open end lugs, the rear will require the removal of the hub, so far I only installed the rear, did not have time to do the front.
half the price, dont have the easy start threads though
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Postby DeeCee » Tue Sep 18, 2012 6:20 am
i found studs with the same spline count as the factory ones. I cut my studs down to suit my application.
From there, I pressed out the hub, pressed the studs out, pressed the new studs in and pressed the hub back in (note I did install new bearings because that was part of the activity I was doing)
DeeCee
Postby woot woot » Tue Sep 18, 2012 6:34 am
Thanks guys.
woot woot
Postby DeeCee » Mon Feb 18, 2013 4:21 am
While this post is old, I was PM'd regarding info on my studs.
Sharing is caring :)
The stud's I used were NS3400 from Nice products.
http://www.niceproducts.com.au/catalogu ... /wheel.php
(go to longer wheel studs area)
Knurl Diameter = 14.4mm
Length = 73.0mm
Shoulder = 8.8mm
Manufacturer specs here (pg2)
http://www.niceproducts.com.au/catalogu ... Toyota.pdf
Factory spec:
Knurl Diameter = 14.1mm
Length = 40.4mm
Shoulder = 7.7mm
I cut my studs down to suit my application (which didn't end up happening with the brake kit I ended up with). But those are the products and specs for the studs which should help others.
Cheers
Dave
DeeCee
Postby Scrap Metal » Mon Jan 23, 2017 9:30 pm
Oem toyota landcruiser studs are not longer. They are the same part number.
2nd gen Tacoma rear studs have a longer shoulder, but same knurl and diameter.
They are 5mm longer. I have fit them on my front hubs with no modification.
...not much longer but being able to buy them from the local auto store for $2/stud was a nice alternative especially with 5mm spacers. 8mm spacers puts thread engagement right below minimum with my rpf1 wheels.
I'm just adding to this old thread for anyone searching
Also... minimum thread engagement on 12x1.5 wheel studs is 12mm or 8 turns.
Scrap Metal
Postby MWP » Wed Jan 25, 2017 3:23 am
I use these with open-ended wheel nuts:
https://niceproducts.com.au/product/s34 ... eel-studs/
