165 ABS Delete How to?
Postby TRDTurko » Fri May 09, 2014 11:59 am
Can someone please do a write up on how to delete the ABS on a 165? I am about to do this as I have a leaking brake line and want to replace the rusty lines with new ones and don't want to make 8 freaking lines. I have half an idea of what I have to do but I still have some questions; like will I need a proportioning valve? which order to plum the lines coming out of the valve going to each wheel. What to do with the wiring on the abs brick and how to keep the abs light off ect...
88 Celica GTS - RIP
93 Honda Civic - RIP
85 Honda Civic - Sold
08 Mazda 3 - Daily
TRDTurko
Re: 165 ABS Delete How to?
Postby 88gt4DE » Sat May 10, 2014 11:28 pm
I havent done it yet but you have to fab the lines at this point ( discontinued ) and find a non abs car prop valve ... someone on here is doing it right now ...
Postby kny48 » Tue Dec 30, 2014 9:27 pm
Has anyone done this? And what the benefits of deleting the abs?
kny48
Postby 88gt4DE » Thu Jan 01, 2015 7:26 pm
Havent yet but it closer to getting done now that I have a garage and if another line leaks. The old abs sucks and the unit is heavy. Benifits really prol not much but you lose weight of that brick and a spot to put something else. Where the lines end up leaking you really can't get to them to repair them when you have a problem either ... :bangshead:
Postby zaluss » Fri Jan 02, 2015 4:50 pm
Besides the weight loss, I thought one of the benefits was the ability to use the rear aftermarket swaybar from an ST185. The ST165 one compensated for the ABS module in the rear.
I could be wrong.
zaluss
Postby 88gt4DE » Sun Jan 04, 2015 10:58 pm
First time I ever heard that ... Interesting for sure :)
