Has anyone lifted their Celica?
Re: Has anyone lifted their Celica?
Postby Domspun » Thu Nov 07, 2019 1:12 am
Oh nice. What's the height of the front bumper? This is with stock shocks and springs?
Domspun
Postby FC Zach » Thu Nov 07, 2019 3:57 am
underscore wrote:This is without settling the suspension at all, so it should drop a bit. For reference those are 205/55R16 tires.
:shock: That's neat! are the axles angles ok?
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby underscore » Thu Nov 07, 2019 4:31 am
This is all with the stock springs + struts + the 1" spacers on top. I haven't taken any measurements yet but I will once I've settled the suspension. Measurements off a stock GTFour are 14.25" from the center of the hub to the fender lip directly above, so I'm expecting 15.25" with the spacers. That gives you a true ride height to compare to without things like variance in tire diameter affecting it.
The axles looked fine when I was assembling everything but we'll see if there's any funny noises once it's on the road. I imagine they'll be fine as Toyota made these cars tough as nails and my Jeep that also has IFS has a 2.5" lift and the CVs are fine.
Postby Numbchux » Thu Nov 07, 2019 8:57 pm
Looks so good, and I imagine it'll do very well. Now take those mudflaps off and throw some dirt :evil:
-Chux
'91 Celica GT vert, poly bushings, rear discs, etc., Summer DD
'87 unTurbo 4Runner, 1UZ swap, 35s
Outbacks, XT6, SVXs, and a couple Ford vans.
Numbchux
Postby underscore » Sat Nov 09, 2019 6:20 am
I snapped a picture of the CV angle up front, it looks pretty tame to me.
Postby FC Zach » Sat Nov 09, 2019 9:30 am
Wow, not bad at all!
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby underscore » Mon Nov 18, 2019 8:30 pm
I put the car through its paces at a TSD this weekend, the suspension is definitely settled in now. Loaded up with all our gear, a full sized spare and a full tank of fuel the front sits about 1.25" above stock and the rear was only 0.5" above stock. For normal use I expect it'll be more level but I'll be adding another piece to the rear so it's level when prepped for an event.
Postby FC Zach » Tue Nov 19, 2019 4:16 am
Very nice!
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby awdmofo » Sat May 23, 2020 11:08 pm
Im digging it! I wanted a 1 to 1.5" lift on mine.
2nd gen Part out! https://www.alltrac.net/phpBB2/viewtopic.php?f=15&t=53417&p=489623#p489623
Full interior part out! https://www.alltrac.net/phpBB2/viewtopic.php?f=15&t=53399
awdmofo
Postby underscore » Sun May 24, 2020 3:28 am
I still love it, I've since added another 0.5" spacer to the rear to try and cure the saggy butt it got from having a full sized spare and a trunk full of gear but I haven't driven it like that much. Eventually I'd like to make it easier to swap the lift in and out too, getting the struts assemblies in and out in the rear is really annoying (the front is a breeze)
