MR. LEADFOOT
My ST165 is pulling to right. The only thing I've done before it started
to pull was installed Whiteline front sway bar. If the sway bar wasnt centered right would it be the problem.
What I done to tryed to fix the problem is new Super Pro bushings, 4 weel alinement and checked tire psi.
Any ideas what could be the problem.
THANKS
THANKS
