Hi.
Have a 165 with 205 front brake setup, but looking for some front discs ( preferable floating ones) that will fit without the 5mm spacer between the hub and the disc.
I really need the last 5mm back to get the front wheels to fit.
Anyone know if someone makes this? ( guess just some floating st205 front ones could be modified to have the disc itself moved 5mm out to.. )
