Almost...
You still have to make a calipers bracket.
*Disclaimer - messing with your braking system can have unintended consequences. This info is an excersize in the limititations I've set for myself in how I approach my car. Use as many toyota or lexus parts as I can. Do it on a budget but dont be (too)cheap. Things like cheap rotors and pads can easily be replaced with something better if it works out.
So ive been doing a lot of off and on research in to brake kit upgrades for a couple of years now. I've seen the threads on modifying st205 calipers, Porsche brembos and sti rotors etc.
I found a couple of options people may want to know about. These are Acura RL and Lexus LS430 calipers from the early 2000's. Both of these are radial mount just like the Porsche Brembo calipers. So making a caliper bracket isn't terribly difficult.
Now the Acura RL calipers would work fine since the rotor is around 330mm if I recall correctly, but the real winner to me is the LS430 caliper and rotor.
It's a 4 piston monoblock aluminum caliper and 12.4" (315 mm) rotor in stock configuration on the LS430 designed to stop a 4000lb car. The best thing about it is the rotors fit perfect on the 96-2000 Rav4 hubs which just so happen to fit our axle shafts and wheel bearings.
