93celicaconv
Member
Does anyone know of an option to just replacement the front & rear suspension rubber bushings on things like the Rear Strut Rod Assy's, No. 1 & No. 2 Rear Suspension Arm Assy's, and Lower No. 1 Front Suspension Arm Assy's? Using part names from Toyota.
I know the rear axle carrier sub-assy's use the lower ball bushing assy (42210-14010), even though the ST185 version does not call those bushings out separately. I'm hoping maybe someone has the Toyota Part No's for these rubber bushings too, even though the parts above typically come with the bushings installed (bushings not sold separately for the ST185's).
I don't want to consider poly - I prefer the softer feel that rubber bushings provide, as they were when originally built.
Appreciate any inputs anyone has.
