please post your max tire sizes on 16" wheels
Postby silence » Fri Aug 27, 2004 12:37 pm
I'm interested in the widest tire that will fit on the 2000 gts wheels. they come with 205-40-16. i'm interested in fitting 225-45-16. has anyone done this?
thanks guys
06 WRX, 90 Celica Alltrac & 88 BMW TURBO 325is
http://www.youtube.com/watch?v=Ei5P9LfLRdg
silence
Postby mtbgael » Fri Aug 27, 2004 12:50 pm
I don't know how wide those wheels are. You should probably be running 7-7.5" wide wheels for 225s. My eclipse has 6.5 wide, and I'm running 225/45/17...with a good bit of sidewall bulge.
Restoring an '88...
mtbgael
Postby silence » Fri Aug 27, 2004 1:21 pm
i'm pretty sure they are 6.5" wide also, thanks for the info.
silence
Postby Rick89GTS » Mon Aug 30, 2004 3:41 am
silence wrote:i'm pretty sure they are 6.5" wide also, thanks for the info.
Affirmative: 6.5" wide for the 2000+GTS rims.
Maybe these tire calculators will be of some help:
http://www.miata.net/garage/tirecalc.html
http://toy4two.home.mindspring.com/offset.html
Rick89GTS
Postby Gary » Mon Aug 30, 2004 5:37 am
Also, Tirerack lists rim width range for each tire.
Clik on the tire model and the spec.
For example, my Yokohama AVS ES100
Scroll down to 225/45/16, it only fits 7-8.5 inch rim,
While the 225/50/15 fits 6-8 inch rim.
More infor on rim width range:
http://www.tirerack.com/tires/tiretech/tirespecskey.jsp#rimwidthrange
93 ST185
Gary
Postby tweekgt4 » Tue Sep 07, 2004 9:49 pm
do not put 225/50/16 tires on the GTS rims. it will jack your acceleration and speedo. it's just too big. 225/45/16 is the biggest you can go on GTS 16s without adding too much change to the tire ratio.
fyi, it's 16x6.5" and each rim weighs about 22 pounds (without a tire).
1999 Volvo V70R, Laser Blue
2001 BMW M5, Titanium Silver
http://www.brsf.net
tweekgt4
Re: please post your max tire sizes on 16" wheels
Postby Conrad_Turbo » Fri Sep 10, 2004 10:56 pm
silence wrote:i'm interested in fitting 225-45-16. has anyone done this?
thanks guys
Yup I've done it, Kumho 712's. Lets just say it takes 2 guys to mount the tires and it's not easy.
Conrad Andres
Mint Design
mint-design.ca
Conrad_Turbo
tire size
Postby silence » Mon Sep 13, 2004 5:38 pm
Just got my new Falken Azenis 215 45 16 mounted on my GTS wheels, and i have no rubbing issues. The rears ARE close...about 3/8" from the strut. Let me tell you, these tires are sticky!
silence
