Koni Race Strut Inserts and Ground Control Coilover Kit
Postby SBCelicaGT » Sat Aug 27, 2005 7:13 pm
For reference purposes, I thought I'd let you guys know of my suspension project going on currently over at Celicatech.com:
http://celicatech.com/forums/showthread.php?p=103412
I've got a good bit of work left to do, but this morning I test fit the strut components together on one of the struts and everything fit perfectly:
Front Strut Mockup
I'll post the finished pictures here and a list of part numbers for those that wish to pursue this option in the future since the only difference for you ST185 folks will be the rear strut body and spring choices. I hope to have the struts ready for install in the next 2 weeks.
Stay tuned.
Adrian
Adrian Avgerinos
90 Celica GT-V6
SBCelicaGT
Postby alltrac.net » Thu Sep 08, 2005 5:28 am
looks nice, but you better not be keeping the rubber upper mount!!!
:shoots:
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net
Site Admin
Postby SBCelicaGT » Thu Sep 08, 2005 2:19 pm
robert@alltrac.net wrote:looks nice, but you better not be keeping the rubber upper mount!!!
:shoots:
I most certainly did. :lol:
I couldn't justify the funds needed for aftermarket aluminum mounts and their aren't any on the market I'm particularly thrilled about. Besides, with the upper rubber, the NVH is rather minimal. In fact, the ride is silent. My only complaint is that I may have chosen springs that are too stiff. If I find the camber bolts won't suffice, I'll probably make my own adjustable upper mounts in the future. Remember, this is a street car. ;)
Here are some completion photos from the Celicatech thread:
Front End
Rear End
Rear Strut Comparison
New shorter strut on right
Front Endlink Installed
I had the vehicle lowered approximately 1.5" but forgot to trim the bump stops prior to installation:
Front has approximately about 0.5" travel left.
Rear has about 0.75" travel left.
Oops! I found that rather than taking apart the entire thing, if I jacked up the vehicle I could trim the bump stops with a pair of dikes:
I took off about 1.25" leaving about 1", which should be adequate according to Koni. This leaves approximately 2" of compression travel, and at least 4 inches of rebound travel, which ought to be plenty.
Comparison photos
I thought I had taken a photo prior to this project, but I can't find it. Offhand, this is the best stock ride height image I have:
Also, for those that are curious, with a fake me in the driver seat (~170lbs), the corner weights came to:
Front
L 950lb /// R 920lb
Rear
L 512 lb /// R 481lb
Total(~11/16 gal of gas): 2864 lb w/ trunk stripped
The toe is set at just about 0 at all 4 corners and the camber is about -2.2 in the rear and -1.5 in the front.
At this point, it's just going to be a matter of getting used to driving the vehicle as it handles completely different now. I also need to work on the damper tuning. I've got the fronts at 1/2 turn and the rears at 1.75 turns. I may turn up the rears a bit if the ride improves.
Adrian
Adrian Avgerinos
90 Celica GT-V6
SBCelicaGT
