www.rockauto.com seem to sell rear struts for ~65$ each, manufactured by KYB, performance should be OK for daily driver
back here in Europe, we can get our hands on on cheap Bilstein "reversed" type shocks, manufactured in Russia
(they cost about 50-70$ a unit, last for about 1-2 years), they are like RIalltrac described whiteline inserts, but come with a casing, just like any ordinary shock absorber, then we cut off top end, weld on this top from any other strut that is 'cartridge' type, insert our new shock in and tighten it up
it took me about two hours for each strut to convert it for new shocks
there also is a problem with rear upper shock mounts, they tend to worn out quickly if stiffer shocks/springs are used (we mainly use these gt4s for rally-type driving, gravel roads I mean), and again, there is a cheap solution, take a similar front shock mount of any FWD car, make an adaption plate or just drill new holes for bolts that matches your cars mount pattern and there you go - you now have a reinforced shock mount
this worked on my car as I had to replace worn mounts for my rear "reversed" coilovers (custom made) each 2-3 months
