Later wiring harnesses in ST165
Postby Maet » Mon Oct 19, 2020 6:06 pm
A lot of the wiring in my 165 wiring harness is brittle and old, is there any other options for a different wiring harness all together, such as a 205 or later 3SGTE harness?
Maet
Re: Later wiring harnesses in ST165
Postby grip-addict » Mon Oct 19, 2020 10:29 pm
Later revisions will plug in to the ecu but the wiring mapping is different between generations. The pins will go to different places, sensors, etc. Take a look at the ecu diagrams at http://gt4.mwp.id.au to see the differences.
This could be quite a large undertaking if you are uncomfortable with wiring.
The closest harness would be from a st185 but you will have to deal with the intercooler differences at a minimum.
Good luck!
grip-addict
Postby simple » Tue Oct 20, 2020 12:51 am
Ask Doug from Wiregap to make you one. He may have enough leftovers to make it.
Mr220v@gmail.com
simple
Return to EFI Corner
