Allright. I have an 88 st165. I just put in a supra CT26, 3" Aussie DP (stock midpipe for a couple months), CV half shafts, full tune up, swapped IC pumps, etc. It took me 3 months to get everything done.
Before I changed turbos: I was getting hesitation/cutting out during boost. I assumed this was from the wheel in the turbo hitting the housing, or the mass of turbo oil that had blown all over my spark plus.
Now: At first, it started running with hesitation/sputtering for the first few minutes while parked revving from idle to 3k rpms. I took it out and it boosted very well. I figured, no problem, It just needs to warm up. I got a code 41 and a code 54.
Then it continued to do that on every start, then in continued to sputter a little more when warm. Also, it began fuel cut when boost would start (any boost). I got a code 35 matched with a 54.
Then I reset the ECU and took it out again. I got boost a couple times, then I had similar problems. It had complete fuel cut at the beginning of ANY boost. I checked the codes: I saw my old friend the code 54, as well as 41 and a 34. My question: What do I do now? Where do I start? I'm a bigtime newb and need help... I gotta get this thing running right.
