This is a chronic problem that has been plagueing(sp) my car for 2 YEARS!! The last year has been on and off trying to diagnose it since I don't have the cash or time to fix it and its getting so frustrating I am thinking of just selling the car- its kicking my butt this bad. I just don't get it.
SYMPTOM: The car will misfire really bad at upper RPMs, usually around 5500. On the dyno I might get one run where it won't misfire but 99.99% it will. But this only happens when we turn the boost 18 PSI or higher. It runs much nicer below that PSI level.
What we replaced: We replaced the spark plug wires(switched from Nology to TRDs), spark plugs(tried different gaps, the car liked .026"), distributor(oem), oem rotor, different coils, replaced the MSD with oem igniter and it actually misfired WORSE!, replaced the Haltech E6K with a E6X and it didn't help-- it just misfired less but now the car would die when it misfired, so we switched back to the E6K-- which we sent out to haltech to have checked out and updated. All wiring was supposedly checked by my shop.
According to them all wiring was checked, they traced it as an ignition issue. They used a spark plug tester that tests the output of the MSD and found it to be giving a healthy spark. All pickup signals to the ECU, and all signals to the ECU are good.
I believe my fuel pressure is around 42 PSI, using low impedance injectors ( 880CC from Precision Turbo), the shop said they are having best results with the injectors at 3.2ms saturation but are going to check the injectors next.
Here are my mods:
JE pistons 9:1
Block bored .020" over
HKS 1.6mm HG
Ferrea dual valve springs
stock cams
stock cam gears
RPS exh. manifold
ChrisK intake manifold
Spearco A/W single core
Turbonetics T3/T4 ( size is similar to a 60-1 )
custom DP mated to an apex-Gt exhaust
MSD SCI ignition box
TRD wires/ NGK copper plugs .026"
Haltech E6K
MSD blaster coil
Precision Turbo 880CC injectors
custom fuel rail w/ FPR
If I don't figure this out soon I may just sell this car.
Basically everything the dyno and all the tests done show its a weak ignition according to them, but after all this was replaced I don't get it. I don't think he is ripping me off either since he is doing this for no charge--he wants to fix this issue ASAP as well since this was unexpected. We have tried everything we can pretty much think of but with no hopes.
