killer_siller
New member
i'm looking for the ignition section of the BGB for any coil on plug 3s-gte. specifically the ignition diagram.
built2run":1l8d2i42 said:is that red top or black top? i was also interested in the coil on plug setup as it has way higher voltage through the spark, less of a chance for ign missfires and a better burn- let me know how that goes i think the ICM needs a matching "NE" signal from the distributor to work right.... i could be wrong.
built2run":3615pdui said:i asked one of my instructors at De Anza Autotech about this COP idea and he tolled me that if the NE signal that our distributor sends matches the NE signal that the ICM on the black-top beams (altezza) engine recieves, then its just a matter of wiring it in if the ICM only needs the NE signal that is. maybe if i could find scan tool readings on the "rev 4" 3sge's ign. signals and see if they match.
