did you fix your problem?
I have the same hesitation. It occurs seldomly when i boost. What i`ve noticed so far:
1.changing plugs didnt do nothing
2.changing fuel filter seemed to fix it for week (maybe i have junk in gas tank)
3.its not that boost dependant, more throttle
4.after long drive (like 50km) at some 120km/h this becomes very possible - i switch into 4th gear to overcome someone and the car just doesnt go as i press the accel. going fast for long time makes engine bay pretty cold, dont know if that matters.
5.after turning car off for 10 mins (after the long drive), then starting back up - cannot get hesitation again!
6.doesnt matter if tank is full or empty
7. gas - 98/95 - doesnt matter
wires, rotor and cap not changed YET
also could be injectors all in dust..
