for those of you out there running the AEM EMS, are any of you guys using the 2step feature and antilag? if so how did you set it up do you see a difference in 1/4mile ETs?
Chris "O" is using the "flat shift feature on his autronic. Its kinda like anti lag. I know they are two different units and i have been out of this kinda reasearch for a while but if the AEM utilizes the same idea as the autronic and does it correctly it should work great. Chris loves it. http://www.turbocelica.com/TheShuttle/AutronicEMS/FlatShift.htm
