Where do I hook up the vacume lines for the HKS FCON. which hose do I use? Thanks Noah
N nynoah75 New member Dec 11, 2004 #1 Where do I hook up the vacume lines for the HKS FCON. which hose do I use? Thanks Noah
L -==L=a=N=c=E==- New member Dec 12, 2004 #2 Plug into the same line which the stock MAP sensor uses. Basically any vaccum line you can get your hands on.
