MSPNP Alltrac owners...some f/b please!
Postby gt4tified » Fri Mar 15, 2013 2:47 pm
Any of the alltrac/gt4 owners running the mspnp? I'd like to get some feedback on how your engine has been responding to the system, how versatile it is, any issues in installing etc.
Giving serious thought to going this route soon.
Thanks.
gt4tified
Images: 5
Re: MSPNP Alltrac owners...some f/b please!
Postby UtahSleeper » Fri Mar 15, 2013 2:48 pm
Curious if anyone has done this also. Probably going to use MS on my trac when I replace the motor.
UtahSleeper
Postby klue » Fri Mar 15, 2013 8:42 pm
I've used it what do you guys want to know
Postby gt4tified » Sat Mar 16, 2013 1:13 pm
Overall, is it good value for money for a standalone EMS for a street car with moderate power mods?
Is it as easy to install as they claim, especially for someone with no prior experience?
Is it easy to tune a base map for different sized injectors and cams?
Does it offer boost control integration with an ebc as well as with a standalone wideband afr system?
gt4tified
Images: 5
Postby klue » Sat Mar 16, 2013 1:31 pm
gt4tified wrote:Overall, is it good value for money for a standalone EMS for a street car with moderate power mods?
Good value yes
The next two questions are based on your skill. It is not plug and play, and you have to assemble the board yourself. Which if you have never done before or are not to proficient there is a chance you can mess it up. In any case if your not a tuner you should not be tuning it anyway, because again there is a good chance of messing up your engine :(
There is no such thing as a base map, there are maps to start the car and thats really all they are good for. You should never drive around with these maps, the EMS should be professionally tuned. You can unlock portions of the software to use auto tune with your wideband, and boost control with a compatible solenoid.
Postby brutekiller787 » Sun Mar 17, 2013 12:01 am
I was looking into this as well and i have talked too the CS of diyautotune and they said that it would work with stock ignition, isc valve and other things that previously didn't work. Sequential injection is an add on, as well as closed loop boost control.
brutekiller787
Postby UtahSleeper » Sun Mar 17, 2013 1:58 am
There base tune can be used. I did add MS to my corolla and started tuning with the base map it generated. Mind you, I did a small amount of research, was very conservative and slowly did street tuning. So, you can get it driving safely with knowledge and street tuning, but a good dyno tune would help too.
I am just curious how useful the PnP setup is after assembled.
UtahSleeper
Postby Matt Cramer » Tue Mar 19, 2013 6:51 pm
You may be thinking of a different MS variant like the DIYPNP; the MSPNP is a complete, assembled unit that is ready to take out of the box and install. With the DIYPNP, well, the DIY comes before the PNP. You do need to add a post-intercooler IAT to use the MSPNP on these cars.
Matt Cramer
Postby gt4tified » Tue Mar 19, 2013 8:24 pm
Matt Cramer wrote:You may be thinking of a different MS variant like the DIYPNP; the MSPNP is a complete, assembled unit that is ready to take out of the box and install. With the DIYPNP, well, the DIY comes before the PNP. You do need to add a post-intercooler IAT to use the MSPNP on these cars.
Yes, Matt is right. I created this thread to enquire specifically on the MSPNP for the alltrac. Matt, maybe you can answer those questions of mine that pertain?
gt4tified
Images: 5
Postby klue » Tue Mar 19, 2013 8:40 pm
I did'nt even klnow there was a pnp option, I just assumed you were talking about a ms3. I've used them on other platforms and a universal one on the 3sgte
Postby gt4tified » Wed Mar 20, 2013 4:02 am
No worries Luke. Lets see if anyone uses it or else I may soon be the guinea pig!
gt4tified
Images: 5
Postby gtfourmansd » Fri Oct 04, 2013 10:13 pm
So whatever happened with this? I have been considering buying this as a first mod sooner rather than later. Not to see any gains but to delete the maf and monitor what is going on with the motor as maintenance and bolt ons are added. Also how complex is the mspnp? The only tuning device i have ever owned was a Diablosport handheld flash tuner when i had my 05 Srt-4. I learned alot from that thing and it was pretty fun making my first street tune and playing with the numbers adding fuel and doing pulls trying to get the knock straitened out. Finally got it dialed in too with good quality gas from shell.
gtfourmansd
Postby gt4tified » Sun Nov 24, 2013 3:15 am
Not too sure, no one has answered.
It hasn't stopped me though...I will be getting the mspnp early next year, just as soon as I get my engine wiring harness sorted out.
gt4tified
Images: 5
Postby UtahSleeper » Sun Nov 24, 2013 3:56 am
I will either be getting a MSPNP or a normal MS later. Maybe spring time. I have a spare harness and I want to do this to clean up the wiring and remove the MAF.
UtahSleeper
Postby gt4tified » Sun Nov 24, 2013 1:34 pm
Nice, feel free to post your progress here.
gt4tified
Images: 5
