ST165 Code 21 bypass - SOLVED
Mateo
Member
Looking to get rid of the O2 heater code with a resistor, but I'm not sure where to insert it into the O2 sensor 4-pin port.
Also it's not an issue of the O2 sensor being bad, I've swapped it out for a Wideband and want to get rid of the CEL.
SOLVED:
Sorry, newbie to everything wiring. Fixed it by running 2 5.6K ohm resistors from the 2 orange/black wires to the red/green wire, it's not like a normal circuit where any ground works it seems the orange/black wires are "connected" only those once connected can complete the circuit. Sorry, can't word it better.
Top
