5SFE w/ 3SGTE head
celicaGTS_T
Has anyone or does anyone know if the head from a 3SGTE would swap onto a 5SFE block (1990 GTS), and if so, what is needed to do so??
celicaGTS_T
Thanks, I wanna go for something that the general public doesnt see happen. Would I have to run an octane rating higher then usual because I'm running higher compression?
SuperWhite92
Boosted or not? You've gotta let us in on a few of your plans so that we can tell you yes or no.
celicaGTS_T
It's a 1990 GT-S. I'm debating whether or not to do a half-trac or just swap the 3SGTE head onto the 5SFE block, thats the ideas so far.
MrWOT
I'd use the 3S bottom end for a single reason, it's got oil squirters, which helps cool the pistons LOTS!
