+42 mm offset might fit, but you have to look at the size of the tires you are using too.
heres a picture of the rear wheel using 17" x 7" wheel with +40mm offset with 215mm wheels.
looks like theres some space left, but when i tried another wheel 17x7 et 42mm with 225mm tires. it didn't fit (damn should of took a picture of that)
so i think +42mm might work if you have 215mm tires.
