did you even bother to read the cam test?
you have already said that you have XX dollars put into this project, so why buy something because its cheaper and convenient? Wouldn't you rather shop around and spend a tad more and get something that is better overall?
tbh, do a 20 thou overboard, run some new pistons, get new big bearings, shot peen the standard 3sgte rods and crank, do some head and manifold work, get new exhaust manifold made up, run a 3" dump no cat to 3" exhaust, run 264s with adjsutable crank pulleys, get new water pump, rebuild oil pump, install decent clutch and install new LW flywheel, balance up the whole lot, run a t06, run 800cc injectors, run an aftermarket ecu and you've got your power with driveability to go with it
Your goals aren't that great! No need for stroker, no need to have a hard car to drive around, no need to waste money just because it would be cool
while the engine is out, clean and detail everything as it comes off, brackets, pulleys etc. Clean up your engine bay with some simple green.
no need to send to the chromers, just a wire brush, then some sanding and buffing on a bench grinder with a polishing wheel on it will bring everything up spanky. Cover in a clear poly plastic coating and you're good to go
use some nice silicon hoses and/or braided hoses and colour coordinate and you're done. The braided hoses don't even have to be expensive ones, unless you are going to be running high high power!
Then you really deserve to be in your magazine with a clean car and engine bay, putting down power to the ground the intelligent way without overspending and blowing budgets
